Common Components
Common components are the parts and modules you'll most often encounter when assembling an iDryer-like device or 3D printer peripherals.
Purpose of this section:
This section serves as a reference for parts you'll actually hold in your hands during assembly.
You don't need deep electronics knowledge here. The main goal is to help you understand:
  • what this component is;
  • why you need it;
  • how it's typically connected;
  • what you can substitute it with;
  • what parameters matter when buying;
  • what most often breaks on first connection.
Format of each page:
  • what it is;
  • where it's used in iDryer and 3D printer peripherals;
  • what a typical connection looks like;
  • important characteristics;
  • typical mistakes;
  • a short checklist before buying.
Proposed files:
  • 02-heaters.md - heaters: PTC, silicone pads, cartridges, 12V/24V/110-230V AC.
  • 03-fans.md - fans: 2-pin, 3-pin, 4-pin PWM, voltage, current, noise, airflow.
  • 04-thermistors.md - thermistors: NTC 100K, lookup tables, mounting, open/short circuits.
  • 05-led-strips.md - LED strips: 5V/12V/24V, regular and addressable, current per meter.
  • 06-servo-motors.md - servo motors: power, signal, angle, peak current.
  • 07-load-cells.md - load cells: HX711, calibration, mechanical mounting.
  • 08-oled-display.md - OLED: I2C/SPI, address, power, when needed.
  • 09-touchscreen.md - TFT/touch: UART/SPI/HDMI, power, compatibility.
  • 10-rfid-and-nfc.md - RFID/NFC: cards, tags, frequencies, connection.
Reference Materials
See Also
  • Heaters - the riskiest type of load: power, temperature, SSR/MOSFET and independent protection.
  • Fans - airflow, static pressure, 2-pin/3-pin/4-pin and power.
  • Thermistors - temperature sensor as the basis for heater feedback.
  • Connecting a fan - practical example of component connection through a power switch.
  • Heater and SSR errors - common mistakes with high-power and mains loads.
