What is STL
STL is a file containing the geometry of a 3D model.
In simple terms: STL tells the slicer what shape to print. But STL says almost nothing about how to make that part strong, heat-resistant, and safe in a real device.
Therefore, the statement "I have an STL file for an enclosure" does not mean you have a complete assembly instruction for building a device.
What STL stores
STL describes the surface of a model as a set of triangles.
The slicer takes this geometry and converts it into print paths.
STL is useful because:
  • almost all slicers understand it;
  • it can be exported from most CAD programs;
  • it is simple to exchange a model;
  • it is well-suited for one finished part with simple geometry.
But STL's simplicity is also its limitation.
What STL does not store
A typical STL does not store:
  • material;
  • color;
  • print orientation;
  • layer height;
  • infill;
  • number of walls;
  • temperature settings;
  • support type;
  • fasteners;
  • assembly instructions;
  • tolerances;
  • part purpose;
  • heat warnings;
  • information about where the part will be weaker.
This means two people can print the same STL and get different parts.
One might print PLA quickly and nicely. Another might print ASA with more walls and the right orientation. The parts look similar externally, but next to heat they will behave differently.
Why this matters for heated devices
For a decorative cover, STL is often sufficient.
For a part near a heater, it is not.
You need to know:
  • what material to print it from;
  • what temperature will be nearby;
  • will the part hold a load;
  • are there wires nearby;
  • will the sensor shift if the part deforms;
  • will the part block airflow;
  • will plastic get too close to a terminal or heater.
If an STL is downloaded without information about material and working conditions, it cannot be considered a ready solution for a dryer, printer chamber, or heating module.
FDM parts are made of layers.
Because of this, the same model can be:
  • strong at one orientation;
  • weak at another;
  • prone to delamination under load;
  • bad for screw fastening;
  • only good for decorative use.
For example, a thin bracket can hold a load well if layers run along the direction of force. But the same bracket can break between layers if printed the other way.
STL itself does not say how to orient a part correctly.
Slicer settings also matter
Even with the right material and orientation, print settings affect the result.
For a functional part, these are important:
  • number of perimeters;
  • wall thickness;
  • top and bottom layers;
  • infill percentage;
  • print temperature;
  • cooling;
  • supports;
  • line width;
  • interlayer adhesion quality.
More infill does not always solve the problem. Often for an enclosure, bracket, or air duct, walls, perimeters, part shape, and load direction are more important.
What you need before printing a working part
If a part will be part of a device, you need more than just the STL. You need a brief set of requirements:
  • material;
  • orientation on the bed;
  • recommended wall thickness and infill;
  • whether supports are needed;
  • what screws and inserts to use;
  • where the part cannot be placed near heat;
  • maximum working temperature of the zone;
  • how to check fit after printing;
  • what to do if the part deformed.
This is especially important for:
  • heater bracket;
  • air duct;
  • fan mount;
  • temperature sensor holder;
  • electronics enclosure;
  • terminal bracket;
  • parts near 110-230V AC.
STL, 3MF, and project files
STL is the simplest and most compatible format, but not the most complete.
The 3MF format was created as a more modern format for 3D printing. It can store more data: not just geometry, but also some information about materials, colors, objects, and manufacturing settings.
Many slicers can also save a project file. Such a file is useful because it stores not just the model but also the orientation, print settings, modifiers, and placement on the bed.
A practical rule:
  • STL is good for passing a shape;
  • 3MF or a slicer project is better for passing print intent;
  • text instructions are still needed if the part affects safety.
How to evaluate a downloaded STL
Before printing a downloaded part, ask yourself:
  1. Is it clear what material to print it from?
  2. Are there any temperature warnings?
  3. Can you see what orientation it was printed in?
  4. Are there photos of the real part in assembly?
  5. Are screws, nuts, inserts, and tolerances specified?
  6. Is it clear what load it will hold?
  7. Is there a risk that deformation could create a dangerous situation?
If you do not have answers, the part can be used as an idea or prototype, but not as a guaranteed safe working component.
Common mistakes
  • treating an STL as a complete instruction;
  • printing a working part from PLA just because it is easier;
  • not changing print orientation for load;
  • using too few walls and hoping high infill solves it;
  • not accounting for temperature inside the enclosure;
  • not checking gaps after printing;
  • screwing into thin posts without margin;
  • using a downloaded enclosure near heat without understanding the material;
  • not leaving access for maintenance after assembly.
Key takeaways
  • STL stores shape, not a safe way to manufacture a part.
  • For a device, material, orientation, walls, fasteners, and working conditions matter.
  • One STL can result in a weak or strong part.
  • For parts near heat, you need information about material and temperature limits.
  • 3MF or slicer project files better convey settings, but do not replace engineering review.
