Enclosure design
A device enclosure is not just a box around components.
It must safely hold:
  • heater;
  • fan;
  • sensors;
  • power supply;
  • controller;
  • terminals;
  • wires;
  • connectors;
  • display or buttons;
  • mechanical parts.
For a heated device, a poor enclosure can create a problem even with good electronics: blocking airflow, overheating the controller, chafing a wire, or bringing plastic too close to a hot part.
Start with component layout
Before modeling the enclosure, lay out real components:
  • controller board;
  • power supply or DC-DC converter;
  • fan;
  • heater;
  • temperature sensor;
  • terminals;
  • fuse;
  • wires;
  • connectors;
  • buttons, display, RFID, or other modules.
The enclosure is designed around actual part dimensions, not "roughly this size".
  • where connectors are located;
  • where USB exits;
  • where the reset button is pressed;
  • how the cover will come off;
  • how the fan will be replaced;
  • where the power wire will run;
  • how the board will be mounted.
Separate zones
In a heated device, it is useful to think in zones:
  • hot zone;
  • electronics zone;
  • power wiring zone;
  • user zone;
  • service zone.
Hot zone is the heater, hot airstream, temperature sensor, and nearby parts.
Electronics zone is the controller, display, low-voltage sensors, logic wires.
Power wiring zone is power supply, SSR, MOSFET, terminals, fuses, mains input if present.
User zone is everything touched by hands: buttons, handles, covers, display, RFID reader location.
These zones should not intersect randomly.
Do not place electronics right next to the heater
Controller, display, DC-DC, and wires do not like overheating.
Leave:
  • distance to the heater;
  • air gap;
  • shield or partition if needed;
  • ventilation for electronics;
  • access to check temperature after assembly.
If electronics sit in a closed pocket without ventilation, they can overheat even without direct contact with the heater.
Air must flow where needed
A fan by itself does not guarantee airflow.
The enclosure must direct air:
  • through the heater;
  • through the spool or work zone;
  • through a filter if present;
  • past the sensor at the right point;
  • outside or in a loop as designed.
Poor design can result in a nice fan and almost zero useful flow. Air will follow the path of least resistance, through gaps, around filters, or past the heater.
For air ducts, avoid:
  • sharp narrowing;
  • unnecessary bends;
  • thin long channels;
  • grilles with small open area;
  • filters without a fan with sufficient static pressure.
Make mounts for real screws
Do not count on a self-tapping screw in a thin post lasting forever.
For an enclosure that will be disassembled, better to use:
  • brass heat-set inserts;
  • nuts in pockets;
  • proper board standoffs;
  • standard-size screws;
  • washers where plastic can dent.
For printed standoffs, important:
  • adequate diameter;
  • rounded base;
  • no thin walls;
  • correct print orientation;
  • material clearance around the hole.
If the cover will be opened often, bare plastic threads wear out quickly.
Wires must not chafe
Wires in the enclosure must be secured.
You need:
  • cable channels;
  • spaces for ties;
  • strain relief at cable entry;
  • radii instead of sharp edges;
  • clearance from the fan;
  • clearance from the heater;
  • protection from pinching by the cover.
A bad scenario: user pulls an external cable and the force goes straight to a terminal or board pin.
Better is for the cable to be fixed by the enclosure first, then reach the connector or terminal.
Do not mix mains with low-voltage
If the device has 110-230V AC, the enclosure must be designed much more strictly.
Minimum logic:
  • mains input separate;
  • fuse accessible but protected;
  • mains terminals covered;
  • low-voltage wires not mixed with mains wires;
  • user cannot touch the mains part;
  • wire cannot pull out of the terminal under tension;
  • plastic does not touch hot terminals and power components;
  • grounding is present where required.
Do not invent mains safety "by picture". For the mains part, you need proper terminals, insulation, strain relief, fuses, and understanding of safety requirements.
Leave access for service
The device will need maintenance.
Leave access to:
  • fuse;
  • terminals;
  • controller;
  • USB or service connector;
  • fan;
  • filter;
  • heater;
  • mounting screws.
If replacing a fan requires desoldering wires or removing the heater, the design will not be well-serviced.
Verify at real temperature
After assembly, you need more than just checking that everything fits.
Verify:
  • electronics temperature after extended operation;
  • wall temperature near the heater;
  • is plastic softening;
  • is the air duct warping;
  • are terminals getting hot;
  • have gaps to hot parts changed;
  • does plastic smell;
  • are wires touching hot surfaces.
The first test is best done under supervision with the ability to quickly cut power.
Checklist before printing the enclosure
Before printing, check:
  1. All real components are measured.
  2. There is clearance around boards, connectors, and cables.
  3. Hot zone is separated from electronics.
  4. Airflow has a clear path.
  5. Fan can be replaced.
  6. Filter can be replaced.
  7. Temperature sensor can be checked and reinstalled.
  8. Wires do not pass through sharp edges.
  9. There are places for ties or clips.
  10. Mains wires are separated from low-voltage.
  11. Cover does not pinch cables.
  12. Screws and inserts have enough plastic around them.
  13. Material suits the working temperature.
  14. Part deformation does not make the device unsafe.
Common mistakes
  • designing a pretty box first, then trying to fit wires;
  • not leaving space for connectors;
  • blocking power supply ventilation;
  • putting controller in a hot corner;
  • running mains and signal wires together;
  • not providing cable strain relief;
  • using thin standoffs for screws;
  • forgetting that filters and fans need maintenance;
  • printing the enclosure from PLA for a hot zone;
  • not verifying the enclosure after extended heating.
Key takeaways
  • Enclosure is designed around real components and wires.
  • Hot zone, electronics, power wiring, and user zone must be separated.
  • Air must flow along a useful path, not just "somewhere blow".
  • Wires must be secured and protected from sharp edges, heat, and tension.
  • Mains cannot be mixed with low-voltage logic.
  • Maintenance must be planned before printing, not after assembly.
