Why PLA is risky¶
PLA is a great material to start with.
It prints easily, is inexpensive, produces neat parts, and is well-suited for prototypes. Many first enclosures, covers, and brackets are printed from PLA.
The problem starts when PLA is placed near heat and treated as a full working material.
PLA does not have to melt to become dangerous¶
The main mistake is looking at melting temperature.
PLA can start losing rigidity long before it melts.
For a working part, dangerous is not just "it melted". Dangerous is when the part:
- softens;
- creeps under a screw;
- loses shape;
- releases a clip;
- shifts a sensor;
- blocks an air duct;
- reduces gap to a hot part;
- allows a wire to touch a heated zone.
Externally this can look like minor deformation. But for a heated device such a small change can cause wrong temperature reading or poor airflow.
Where PLA is especially risky¶
PLA is better not used for:
- heater bracket;
- temperature sensor holder on a hot part;
- air duct right after the heater;
- part inside a hot chamber;
- power terminal bracket;
- part near an SSR, MOSFET, or heatsink;
- part under constant load in heat;
- enclosure where 110-230V AC runs nearby.
Even if the part does not touch the heater, it can sit in warm air for long periods. In a closed enclosure, temperature rises not just near the heater but throughout.
Dangerous scenarios¶
Typical problems:
- heater bracket softened;
- sensor holder shifted and temperature reads wrong;
- air duct deformed and flow through heater decreased;
- electronics cover warped and blocked ventilation;
- screw crushed plastic after several hours of heating;
- wire started touching a hot part;
- gap between plastic and terminal became smaller;
- enclosure lost shape but device kept heating.
That is why "it printed nicely" does not mean "will work safely".
Where PLA can be used¶
PLA is not a bad material. It just needs to be used where it belongs.
PLA is suitable for:
- cold prototypes;
- test-fit parts;
- templates;
- decorative covers away from heat;
- handles and pads in cool zones;
- temporary parts for shape checking;
- models that do not bear device safety.
PLA is useful early on: quickly check dimensions, board fit, cover shape, button placement, or air duct direction. But after checking, a working part near heat often needs to be reprinted from another material or replaced with a non-printed part.
Closed enclosure makes it worse¶
In an open room, a PLA part might look stable.
In a closed dryer or printer chamber, conditions are different:
- air heats up;
- plastic stays in warmth for a long time;
- a heater operates nearby;
- airflow might not cool the part;
- there might be a power supply or power module inside;
- load acts for hours.
Therefore, checking "I touched the part with my hand, seems fine" is not enough.
You need to verify the device in real operation: with heating, fan, enclosure, and runtime similar to actual use.
PLA under load¶
PLA is stiff, but that does not mean it holds constant load well in heat.
Bad places for PLA:
- standoffs under screws;
- clips;
- hinges;
- spool holders;
- thin brackets;
- parts compressed by a screw;
- parts holding a spring or lever.
If a PLA part is heated and loaded constantly, it can gradually change shape. This is called material creep.
For an enclosure this is especially unpleasant: today everything is assembled fine, but after several heating cycles the gap is different.
What to use instead of PLA¶
Depending on the task, consider:
- PETG - for moderately warm zones and simple working parts;
- ABS or ASA - for warmer and technical parts;
- PC or PA/nylon - for experienced users and more demanding conditions;
- metal, fiberglass, ceramic, or ready-made brackets - near the heater and power section.
If the question is heater bracket, thermal protection, mains terminals, or critical sensor, do not choose material from a filament list alone. Sometimes the right answer is not to print this part from plastic at all.
How to use PLA more safely¶
If PLA is used anyway:
- keep it in the cool zone;
- do not place near the heater;
- do not use as power part bracket;
- do not load with screw without margin;
- do not make PLA the only safety element;
- verify after extended heating;
- keep gap to hot parts;
- make a prototype, not the final hot part.
For early tests, you can print a PLA part, assemble the device without heating or at reduced power, verify shape, fit, and access. After that, the working part should be reprinted from suitable material.
Common mistakes¶
- ignoring PLA softening and looking only at melting temperature;
- printing heater bracket from PLA;
- placing PLA air duct right after the heater;
- mounting thermistor with PLA in a hot zone;
- using PLA inside a closed warm chamber;
- thinking "if it does not melt in 5 minutes, it is safe";
- not checking deformation after several hours of operation;
- leaving PLA under a screw and load in heat;
- not reprinting the prototype in a working material.
Key takeaways¶
- PLA is convenient for prototypes but poor for hot zones.
- A part can become dangerous long before melting.
- Main risk is loss of shape, rigidity, and gaps.
- PLA can be used away from heat and power section.
- For working parts near heat, consider PETG, ABS/ASA, or non-plastic solution.
- If failure of a PLA part can affect safety, the material is chosen wrong.
References¶
- Prusa Knowledge Base: PLA - PLA as a simple material for prototypes and parts without high mechanical, chemical, or temperature load.
- Prusa PLA product page - practical warning about low temperature resistance and strength loss at temperatures above roughly 60°C.
- Bambu Lab: PLA Filament Guide - PLA as a beginner material for decorative parts and models, but not for high temperatures and demanding applications.
- Bambu Lab: 3D Printer Filament Comparison Guide - comparison of heat resistance and other properties of PLA, PETG, ABS, ASA, PC, and engineering materials.
- Filwiz: PLA Heat Resistance Explained - explanation of the difference between melting temperature, glass transition, and practical heat tolerance of PLA.
