Heating control¶
On this page you connect sensors, settings, and power control into working logic. The device maintains a set temperature in the cabinet, protects the heater from overheating, and responds to commands from the portal.
Logic runs in loop() alongside network servicing. All timers and thresholds are non-blocking, without delay().
What should happen¶
Cabinet behavior follows three simple rules:
- Temperature maintenance. If the cabinet air is cooler than the target by the hysteresis value — turn on heating. When the target is reached — turn off.
- Heater protection. A thermistor monitors the heater itself. If it overheats beyond the limit — heating turns off regardless of air temperature.
- Fan. Turns on to distribute heat throughout the cabinet, and turns off when heating is not needed.
Heater and fan switches¶
The controller turns the heater and fan on and off through a switch: a MOSFET module (version A) or SSR (version B) — see Wiring Diagram. From the code perspective it is simply a GPIO pin: HIGH — on, LOW — off.
Describe such a switch with a small structure and create two instances — for the heater and fan. Add this to src/main.cpp (before setup()):
struct GpioOutput {
int pin;
void begin() { pinMode(pin, OUTPUT); digitalWrite(pin, LOW); }
void on() { digitalWrite(pin, HIGH); }
void off() { digitalWrite(pin, LOW); }
static GpioOutput myHeater{4}; // GPIO4 — heater control
static GpioOutput myFan{5}; // GPIO5 — fan control
Pin numbers are the same as in the Wiring Diagram. In setup() both switches must be initialized: myHeater.begin(); and myFan.begin();.
Safe state on startup
begin() immediately sets LOW — heater and fan are off until logic decides otherwise. This is important: when power is applied, the heater must not accidentally turn on.
Temperature maintenance by hysteresis¶
For a cabinet in the 40–45 °C range, simple hysteresis is sufficient: heating turns on and off around the target. This is simpler than full PID and works reliably for gentle heat maintenance.
Target temperature and hysteresis are taken from the menu (menu.target_temp, menu.hysteresis) — it is already connected in chapter 6. Add a state flag and decision function:
static bool s_heating = false;
static void controlLoop() {
float air = s_link.telemetry.airTempC[0]; // SHT31
float target = (float)menu.target_temp; // from menu
float hyst = (float)menu.hysteresis; // from menu
if (air < target - hyst) {
s_heating = true; // cooled down — heating on
} else if (air >= target) {
s_heating = false; // reached target — stop
Target temperature and hysteresis are taken from the menu — the user changes them from the portal.
Heater protection by thermistor¶
Air heats slowly, while the heater element heats quickly. Without separate control, the heater can overheat before the air reaches the target. Therefore, the heater thermistor sets a hard ceiling.
static const float HEATER_MAX_C = 80.0f; // heater temperature ceiling
static void applyHeater() {
float heaterTemp = s_link.telemetry.heaterTempC[0]; // thermistor
bool allow = s_heating && heaterTemp < HEATER_MAX_C;
if (allow) {
myHeater.on();
s_link.telemetry.heaterPower01[0] = 1.0f; // reflect in telemetry
} else {
myHeater.off();
s_link.telemetry.heaterPower01[0] = 0.0f;
Heater ceiling is protection, not climate control
HEATER_MAX_C limits the heater element temperature, not the air. The value depends on heater design and enclosure materials. Choose it with margin below the temperature at which printed parts deform — see Heat-resistant materials.
For smoother heating instead of on/off switching, you can control power via PWM; the heaterPower01[0] field accepts values from 0.0 to 1.0. For a cabinet with gentle heat maintenance, the simple logic above is usually sufficient.
Fan¶
The fan distributes heat throughout the cabinet. The simplest logic is to turn it on with the heater:
static void applyFan() {
bool fanOn = s_heating; // spin while heating
if (fanOn) myFan.on(); else myFan.off();
s_link.telemetry.fanOn[0] = fanOn; // reflect in telemetry
In the production controller, the fan is controlled by temperature with separate on and off thresholds (for example, turn on at 55 °C, turn off at 35 °C) to prevent chatter at the boundary. For a cabinet, the same approach can be applied by linking thresholds to menu parameters.
Assemble in loop()¶
s_link.loop(); // network and auto-publish
// sensors (see "Sensors" step):
s_climate.tick(millis());
SensorReading c = s_climate.get();
if (c.ok) {
s_link.telemetry.airTempC[0] = c.temperature;
s_link.telemetry.airHumidityPct[0] = c.humidity;
s_link.telemetry.heaterTempC[0] = readHeaterTempC();
controlLoop(); // decide whether to heat
applyHeater(); // apply to heater + protection
applyFan(); // apply to fan
Telemetry fields (heaterPower01, fanOn) are published by the facade itself — on the portal you can see whether the device is heating now and whether the fan is running.
Commands from the portal¶
The portal sends heat maintenance start and stop as commands. The handler is registered with the s_link.onCommand(name, callback) method — after s_link.begin(). Action commands arrive with the name invoke and a field action (a role from the menu, for example storage.start / storage.stop).
To parse JSON you need the headers <ArduinoJson.h> and <string.h> (for strcmp) — add them to the other #include statements at the beginning of the file. The handler itself goes in setup():
s_link.onCommand("invoke", [](JsonObjectConst data) {
const char* action = data["action"] | "";
if (strcmp(action, "storage.start") == 0) {
s_heating = true;
s_link.status.mode[0] = iDryer::UnitMode::Storage;
s_link.status.targetTempC[0] = (float)menu.target_temp;
s_link.publishStatusNow();
} else if (strcmp(action, "storage.stop") == 0) {
s_heating = false;
myHeater.off();
s_link.status.mode[0] = iDryer::UnitMode::Idle;
storage.start/storage.stop— the same roles you set in the menu; the portal draws buttons from them.iDryer::UnitMode::Storage— gentle heat maintenance mode. This is the cabinet's primary mode.s_link.status.mode[0]andtargetTempC[0]show the current chamber state on the portal.- Call
publishStatusNow()after each status change so the portal sees it immediately, without waiting for the timer.
No delay() in the handler
The onCommand handler is called from a network callback. Any blocking inside it breaks the MQTT session. Change flags and status, but do the actual work in loop().
Complete src/main.cpp after this chapter¶
This is the final, complete file for the device. Lines new relative to the previous chapter are marked // ← chapter 7. This same file is available as a ready example in the example/09-cabinet/ folder of the repository and builds with the command pio run -e cabinet.
src/main.cpp before — after chapter 6
#include <math.h>
#include "Sht31ClimateSensor.h"
#include <menu_state.h>
.deviceType = iDryer::DeviceType::Dryer,
.hasHeater = true,
.hasFan = true,
.hasAirTemp = true,
.hasAirHumidity = true,
.hasHeaterTemp = true,
.model = "DIY Storage Cabinet",
static Sht31ClimateSensor s_climate(&Wire);
static bool s_climateOk = false;
static const int THERM_PIN = 2;
static const float SERIES_R = 4700.0f;
static const float NOMINAL_R = 100000.0f;
static const float NOMINAL_T = 25.0f;
static const float BETA = 3950.0f;
static float readHeaterTempC() {
int raw = analogRead(THERM_PIN);
float v = (float)raw / 4095.0f;
float r = SERIES_R * (1.0f - v) / v;
float tK = 1.0f / (1.0f / (NOMINAL_T + 273.15f) + logf(r / NOMINAL_R) / BETA);
return tK - 273.15f;
Wire.begin(8, 9);
s_climateOk = s_climate.begin();
menu.initDefaults();
if (s_climateOk) {
SensorReading r = s_climate.get();
if (r.ok) {
s_link.telemetry.airTempC[0] = r.temperature;
s_link.telemetry.airHumidityPct[0] = r.humidity;
#include <ArduinoJson.h> // ← chapter 7 (onCommand: JsonObjectConst)
#include <string.h> // ← chapter 7 (strcmp)
#include <math.h>
.hasHeater = true,
.hasFan = true,
.hasAirTemp = true,
// ← chapter 7: heater and fan switches
struct GpioOutput {
int pin;
// ← chapter 7: temperature maintenance logic
if (air < target - hyst) s_heating = true;
else if (air >= target) s_heating = false;
if (allow) myHeater.on(); else myHeater.off();
s_link.telemetry.heaterPower01[0] = allow ? 1.0f : 0.0f;
if (s_heating) myFan.on(); else myFan.off();
s_link.telemetry.fanOn[0] = s_heating;
Wire.begin(8, 9);
myHeater.begin(); // ← chapter 7
myFan.begin(); // ← chapter 7
s_link.onCommand("invoke", [](JsonObjectConst data) { // ← chapter 7
s_heating = true;
s_heating = false;
myHeater.off();
if (s_climateOk) {
if (r.ok) {
controlLoop(); // ← chapter 7
applyHeater(); // ← chapter 7
applyFan(); // ← chapter 7
Verification of results¶
After this step:
- starting from the portal puts the cabinet in Storage mode, the device begins heating;
- air temperature approaches the target and stays within the hysteresis range;
- heater does not exceed
HEATER_MAX_C; - fan and heater power are visible in telemetry;
- stopping from the portal turns off heating and switches to Idle.
What's next¶
Logic is ready. It remains to assemble the device into the enclosure and test under power — Assembly and check.
